As you will still have to skim the wall why not take the paper off and simply skim the wallWant to refresh a bed room , walls under the paper are very poor, plaster is still ok but years of flaking paint etc so I was thinking coving off skirting off leave wall paper on and cover the lot with fresh plaster board?
So how do I do it?
Easily done by rebating thicker custom frame architrave to cover board and tuck into door casingIf you do overboard it you will also have to extend the door lining width refit architrave and rehang the door along with skirting and coving.
Extractor dustmask and a orbital sander. Be done in a few hours.
Na. Bit of 1x1 counter sunk holes. Wood glue and screw it on then fit architrave as normal.Easily done by rebating thicker custom frame architrave to cover board and tuck into door casing![]()
Yeah a lot of work when you can simply skimNa. Bit of 1x1 counter sunk holes. Wood glue and screw it on then fit architrave as normal.
Not hard but why bother if the plaster is good.
