mattiemjbb
I’m having some problems with the plasma cutter I purchased off ebay.
It’s a cut 50 not sure about any other details It appears to be a cheap Chinese one
The problem is thus.
All the lights come on and the air will come out of the end but nothing else, I have been trying with 75 psi and have tried it with higher too upto 120 with no effect.
Whist disassembling the torch to check everything was there I accidentally pushed the button and touched the metal bit of the torch against a piece of earthed metal and it did arc but this was without the electrode nozzle and shield in, so I’m assuming there must be power getting to it.
The compressor is only a small one so I doubt it will keep the correct pressure for long, but shouldn’t it still arc for a moment?
Also the electrode does seem a tiny bit loose where it fits into the torch but it is still in contact around the collar of the electrode#
Could it be I’m net getting enough volume of gas through, does anyone have any idea how much I might need
