reads around that you can notch pipe with a hole saw. i need to however not holes on angles how do the hole saws handle that? and what size hole saew do i use if my pipe is 42mm OD. would i use the closes holesaw below example 41mm or the closes above eg 43mm
the pipe is 3mm wall thickness
