Im quite fed up of making making straight cuts with the grinder now, im doing alot of chassis repairs on 2,3mm thick steel and occasionally abit thicker im thinking with a plasma cutter i can have abit more reliability in getting a straighter cut with a guide… im not wanting to spend much so it will be one of these cheapo ones of amazon. Im stuck between a Pilot Arc or a non Pilot Arc one, are they both as easier as eachother to run along a guide and get a nice straight cut? I’ve seen the Pilot arc ones have a guide thing to stop you touching the material that you could also run along the guide or is a non Pilot Arc just as simple?
Just want some opinions on the pros ans cons of either and if it’s worth just getting the pilot arc.
