- Birmingham
This room can gets very hot even with air con so sticker ones will probably fall off
You can get similar with a central fixing hole, maybe pop rivet them on?.
I usually use the sticky ones to line them up then put a self tapper or wood screw through to fix them, without the screw they always fall off just like sa trunking.You can get similar with a central fixing hole, maybe pop rivet them on?.
