Williamrafferty
New Member
- Sherlock43
Hi folks,
As above, my Peugeot Boxer 1.9td year 2000 has failed the MOT on corrosion.
The corrosion is in the top of the strut tower - both sides.
I have removed the Strut, the wing and the front bumper for improved access.
I have done some mig welding previously but now my age (62) and my health (Brain Tumour) are against me.
Even with the above preparatory works access is extremely limited.
I would therefore, be immensely grateful if someone with experience of this type of repair could advise how they went about it !
I was hoping to stitch / spot weld in new metal to address the issues but it seems that this is not acceptable for the MOT as they specify seam welding where a repair is made to an existing panel.
However, if the original assembly was spot welded in the factory - it is ok to spot weld / stitch in a repair.
My question is - am I correct in my understanding - or is spot welding a repair panel into the front suspension tower not acceptable ?
Many thanks for reading this far,
Will.
Will.
