dan.taylor.1
General Tinkererer
- Kendal, Cumbria
Hi folks
Not sure if this is the right section. Basically I've made some shelves with a pretty rigid frame (40x10 and 20x10) with a 1.5mm perf sheet top (10mm holes on a 30mm spacing?) but some of them have warped in between supports, some haven't.
Pic attached, the shelves bolt into the panels, they're 40x10 sides and rear, with a rolled 20x10 front on its flat edge to minimise height loss, then there are 3 20x10 braces from front to back, again on their flat edge. They're all pretty much tacked/short stitch welded all the way round, including on the braces.
How can I remove the warp. I've got heat but no staging gear to put like a cross in the open area to make it more rigid. Also they're going to be galved so needs doing now as it'll be impossible after!
Any help appreciated.
Cheers,
Dan
Cheers,
Dan
