Think you missed the . Point8mm wire! Must be a good mig!
nothing helpful to add then8mm wire! Must be a good mig!
by v welding an multi passesThat sounds OK - you could run a 3.2mm rod non stop, so the thickness of the metal you're welding should be limited only by your imagination and patience!
For gods sake! Lighten up!! There is a lot of good advice on here and a good bit of banter too.nothing helpful to add then
i know bud, to many beers andforgot about the similesFor gods sake! Lighten up!! There is a lot of good advice on here and a good bit of banter too.
