Thanks predictive text pain in the assTitle edited![]()
And do you know what it does in the welderWell, a PCB is a printed circuit board (so, PCB board is saying printed circuit board board) and it holds all the components that make up the control circuit...
Sorry forgot to addMoved to correct forum, may move again when we find out what make it is !
Yes mine works from the triggerNot all of them.
I've got the remains of a migmate in the shed (the version with the transparent plastic door over the wire housing) and that one uses a gas solenoid and 2 wire unvalved torch.
I've seen a couple of the top loading type be factory fitted with gas solenoids too.
The very much later migmate I had used a torch valve.
Sorry forgot to add
It's a sip migmate 100
I havnt got a clueAnd moved again.
If the gas, arc and feed are cutting out at the same time I'd be looking at a faulty trigger switch.
This is a bit ambiguous, the gas always works from the trigger insomuch as gas comes out when the trigger is pressed. There are 2 ways of doing this, 1) with a solenoid valve in the machine 2) a mechanically operated valve in the torch. Which is yours?
@pdg snap!
I will take a look tomorrow I was thinking about buying a new torch so I will check it out tomorrowIt's easy enough to tell. Follow the gas pipe into the machine. If it connects to a thing with wires coming out you have a gas solenoid. If it goes straight through to the torch then you have a mechanical valve.
