Barlidge
- Langford, Bedfordshire, UK
I want to run a PC quite slow, I've tried it with my variable voltage bench top power supply and works perfectly so I ordered one of the those cheap dimmer modules which also works but makes the fans whine quite audibly.
Would one of these do the job without the whine?
https://www.ebay.co.uk/itm/253016434796?ul_noapp=true
In this warm weather and with the awning up the heat builds up behind the vents, taking the vents off helps a bit but leaves 2 big holes in the side of the caravan so I thought I'd try it with a fan just gently helping the airflow which seemed to help a lot the other day when I left it running on the benchtop psu at something like 7-8v (I'd just use that but its quite big and has a noisy fan in). I'l give this one a go then and see how it goes, thank you.
