nopewhich presumably will confirm/eliminate rack issue?
even if the pump is working it wont dip unless it has some work to doNormally when you operate a car stationary with power steering (driven by a pump) you should see the revs drop/dip as the pump loads the engine, assuming the pump is working!
If you get someone to watch the steering fluid when someone starts u the car, if the fluid level drops pump is working, if not then I'd be saying pump, use a lolly stick so you can see the level has dropped
yes we can hitch but I would like an explanation, if he is going to have a go at me he could at least be man enough to explain his reasoningCan we keep a lid on this please chaps....
And back to the topic in hand.
