rosco454
Hi,
I bought a barley used portamig 211 from a member on the forum last weekend and im really impressed with it so far but have a quick question.
I have a small amount of body work to do so would like to use 0.6 wire however the 250a type 25 torch it comes with doesn't have any 0.6 tips available and has the larger red liner fitted.Is it possible to put a blue liner in and use 0.6 tips from a type 15 torch?They are the same thread but 3mm shorter than the type 25 ones,will they do the job or should I just stop being a tight sod and by a type 15 torch to run the 0.6 wire?
Many thanks in advance,Ross.
Will have a better look around in that case.......must try harder!
