Hi,
After a lot of reading around, I bought myself a brand new Parweld 171 C. Problem is that the wire won't feed properly.
The wire is all the way through to the torch. When I press the trigger away from metal, the wire feeds, but the feed motor speeds up and slows down with each rotation of the wire feed drive wheel.
When I try to weld, the feed motor seems to lack power and the feed is even slower and the wire comes through in pulses corresponding with the rotation of the wire feed wheel.
I ran the wire feed spindle by itself with the wire gripper wheel (not sure of names!) off. Ran smooth. Put the wheel on (wire not in) and ran it against my finger. Feels slightly oval shaped not round.
Is this normal?
Cheers, GDL.
Is this normal?
Cheers, GDL.
