Recently bought a used vw caddy which is in fairly good condition for the age.
There were quite a few holes in the floor from the previous owners plywood panels
There's a little bit of surface rust around the holes on the inside which i can treat and paint.
On the underside there was a bit more rust and the first signs of paint starting to bubble.
Rubbed down the underside in the affected areas and treated with jenolite. Now just need to paint and fill the holes
Really not sure what to use after reading many threads using different products though.
Was originally going to use hammerite direct to rust but since learned its not very good.
Can anyone suggest what i should use?
I'll just be spot painting the areas in question as the rest of the underbody looks fine. Its just the areas around the screwholes.
