Hi all,
I am moving on to painting the exterior of my Herald soon, having completed the underside and interior. I am going to be using Lechler 29107 epoxy primer, Upol no.1 filler and cellulose top coat - I already have a fair amount of these.
Having only used Jotun 87 epoxy which didn't really have a spray pattern due to the thickness, Is the Lechler the same or will I get a decent fan when spraying it, and how "high" is the build?
Also, can someone correct me on this paint order please!
Degrease panels
DA with 120/80 discs
Degrease again
2x coats Lechler
Filler work
Guide coat and block back - what grit do I need?
1x coat Lechler
Guide coat + block back - same grit as above?
Cellulose top coat
Thanks again for any help!
Degrease panels
Degrease again
2x coats Lechler
Filler work
1x coat Lechler
Cellulose top coat
