As the title says, I'm going to repaint my engine bay, the original factory paint is good.
Can I use green scotchbrite pads to scuff the surface before applying epoxy primer, the reason i ask, is because the engine bay is not easy to sand with paper and the pads are more maneuverable into small nooks and crannies.
is the grit enough?
i believe green equates to about 320 (any bare metal will be prepped with a coarser grade sandpaper - 120).
but to scuff original paint , is green pads enough for the epoxy primer to stick?
thanks for the help
is the grit enough?
thanks for the help
