I've got an old Z3 I'm looking to try and tidy up a bit and sort some of the underbody corrosion, so sills and a few other bits. Looking at options for what paint to use to overcoat areas I've had to strip back, mainly for the first coat. Since this is just for touch-up work underneath anything sprayed is no good, I don't have the room to do this, and don't have a decent compressor or paint gun, so this will have to be brushed on. I'm also assuming my prep work won't be great just due to working in a confined space, so need something fairly tolerant of mediocre surface prep (i.e surface won't be keyed well, but all rust will be treated prior to prep). I do plan to try and do a decent job of it where possible, but want something tolerant just in case! I will say as well that I couldn't care less how good it looks when it's on there, the car's not a show piece up top, let alone underneath where nobodys looking, the main goal is to keep it solid.
So far I've ruled out epoxy primer due to how prep sensitive it appears to be, that leaves me with either:
High zinc primer (I.E Bilt Hamber Eletrox) - like the galvanic protection it offers but from what I've heard it's adhesion and mechanical strength isn't great, and would require overcoating with something else. Don't know if there are any formulations with high adhesion/mechanical strength or if they are all much of a muchness? That said I will have to use a bit of it on welded panels just to ensure good coverage inside cavities I can't get to afterwards...
Zinc Phosphate primer - like the sound of this as it claims to have good adhesion, I.E should be fairly tolerant of not great surface prep, assume like other primers it needs to be overcoated after the fact? Does it only stick well to bare metal surfaces or does it stick well to other paint, seam sealer, underbody coatings, etc, as well?
Epoxy mastics - from the sounds of it these are more tolerant of surface prep than the epoxy primers, and some seem to include zinc phosphate as well which I quite like the sound of, though don't know if these would adher as well as a "regular" zinc phosphate paint? Having had a quick look at the data sheets for jotamastic 87 and 90 they seem to require a minimal level of surface prep, is there any reason (aside from cost presumably) not to go with one of these over a standard zinc phosphate primer?
Any other options that I'm missing or are those 3 the best options for what I'm looking for? Also, what are people putting over these as a hard wearing topcoat nowadays? Not touching something like hammerite with a 6 foot pole, and tempted to avoid stonechip as well, unless it can be trusted when put over the top of a good primer (I.E it won't crack and let moisture in)? Appreciate a lot of this has been said before, but most of what I found when searching was either old, or was mainly about full restorations where 2k primer is the best option due to access, etc, which I don't have!
