Pete.
- Kent, UK
I have to do some oxy-propane burning. Steel joist walers and tubular props, probably a couple of hundred tons. I'm no a novice with the burning torch but only use it incidentally to my usual work so though I've used it many time it's never contiuned use.
Now I have a job where choosing the correct nozzle size and gas pressures will make quite a difference to consumable costs, so I'm asking for advice.
I have to burn tubular props with a 12 and 16mm wall thickness. Mostly unpainted with just thin surface rust, such as you'd typically see on sheet-piling that's been in a few months etc.
Also have a large amount of RSJ waler to burn out, 16 to 25mm thickness by the looks of it.
Looking for some reccomendations as to nozzle sizes & pressures to strike a balance between gas consumption and rate of work. Got some new Harris torches to work with.
the only thing i will say is your suposed to use the orange hose for propane and the red hose for acetylene . the reason for that is propane is suposed to rot the red acetylene pipe over time but ive used them for years without detriment
), and made to change the gauges because the lense on one had a small crack (again they were 3 weeks old
