BiTurbo228
New Member
- Kent, UK
Hi folks,
Hoping someone might be able to help! I've recently bought myself an old Oxford Mig 170 (from the 80s I think!). Got everything hooked up but it's tripping the breaker when I pull the trigger. Initial testing suggested it might be the wire feed as with that set to zero you could pull the trigger and it didn't trip, but doing so 5 or 6 times in a row ended up tripping it so I figured that wouldn't be it (or at least not the sole cause). Here's the welder in question:
I've done a bit of electrical work before but it's not my native habitat! Bit of reading suggests it could be a diode on the rectifier bridge, but I'm not sure I'd recognise a rectifier bridge or a diode if it punched me in the face
maybe a diode, although I'm used to the little glass things you see on circuit boards.
Popped the side off the welder and this is what it looks like:
I figure it might be the red and blue things between the big fat wires on the bottom right, but who knows! Anyone know how to go about testing it?
The other thing to mention is that it's on a 32A b-type breaker and I read that with older machines a c-type breaker can be more resistant to tripping on initial startup (or is that specific to the old Oxford oil-filled stick welders?).
Simon
Simon
