Hi guys, having some trouble with overhead welding, basically I'm doing some welding on a car that required some "overhead" welds, it is a horizontal piece onto a vertical piece, 2mm mild steel, the weld doesn't seem to stick at all, it is also getting stuck to the copper tip frequently (stick out of around 8mm at a guess) is it possible that the tips are too small? using 0.8mm wire with 0.8mm tips.
Any help is greatly appreciated, I'm using the lowest setting on my welder (Draper MWD121AT) using 10lpm of BOC Argoshield light wirefeed set to 1.5 on the welder, tension is fine, welding flat is fine with these settings, also welding the same kind of joint but on a work bench it's fine. Really confused by this but I am inexperienced with overhead welding, the majority of my welding experience has been on a work bench.
Any tips or advice? Would be greatly appreciated!
