If you're welding anything of any thickness you need to be spraying. Dip just doesn't penetrate enough.
Don't be silly
How am I being silly? Please elaborate. Are you saying you can't spray overhead, or that spray doesn't give better penetration than dip?![]()
I'm not saying either. It's horses for courses, dip and spray have their place but to say you always need to be in spray transfer and that dip transfer doesn't penetrate enough are very broad sweeping statements that are incorrect and may confuse people.
I imagine you will use spray transfer for your 30mm plate, not because dip transfer won't penetrate (because it will with the right prep), but because it would take a lot more time to perform the same weld and therefore a far less efficient way of working.
If i make a pair of gates out of box section with a 2mm wall thickness do I also need to be in spray transfer? Of course not, and I'd spend most of my day changing rollers, tips and wire to make sure I was always in spray transfer when working with materials of different thickness.
The OP was looking for advice on an overhead MIG butt. The chances are this will be in Material of less than 10mm and if thick enough will include a single Vee prep, the chances are that the employer will be looking for the candidate to root fill and cap. My advice was based on that assumption.
Jim
Has pulsed spray transfer been confused with ordinary spray transfer in this thread?![]()
I didn't say you always need to be in spray transfer.
Yes you did.
I gave advice in good faith which incidently would serve the OP well whatever material thickness he was presented with for his test. Granted if he was given a hefty piece of plate it would take a while to prep and weld.
You on the other hand have offered him no advice and seem intent on picking an arguement based on a very narrow point.
You sound like a "GoodWelder" and we're going round in circles so I'll leave you to it.
All the best, Jim
Can we agree to disagree and knock this on the head please?![]()
Fair enough. Just didn't like the "don't be silly" comment.
Sorry for clogging up the thread![]()
Serious question - and I'm not asking for anybody to start giving anyone a hard time, but how do you do spray overhead on solid wire? I've never successfully done spray on anything other than downhand.
So I'm looking for an idea of volts, amps (maybe), wire feed speed and technique. Ta.
