BrokenBiker
- Newport, South Wales
I found some 1mm steel, cut it from the centre silencer of the megane...
cleaned it all up with a wire brush and started playing with the setitngs on the mig...
now the only way i can get it to run a nice bead, or even tack properly, is to set the voltage to about 4 and WFS to 5...anything lower than this and the wire burns right back to the tip as soon as it hits the metal...this is higher than the setting in the book, but the book says to use .6 wire, im using .8 so i assume the higher CSA of the wire is cooling the puddle more than .6mm would...
the good news is i can run a bead as long as i want on the steel wiithout even trying to blow holes...bad news is the bead on the back is bigger than the bead on the front...
is this an issue? im more concerend with when i eventually move to car repairs i am going to have a load of weld metal on the inside of the panel that has had no gas coverage and will potentially rust?
am i just worrying too much or is it an issue?
