hotponyshoes
- Somerset. Uk
Just looking at having some sheet laser cut and noticed the suppliers are now offering sheet folding as well (although they are closed until next year so I cant ask any questions!)
Just to keep things simple:
A channel, internal dimensions of 200mm base with 2x 100mm sides.
6mm sheet.
The guide from the folders shows a minimum internal bend radius of 8mm.
So, I presume the external bend radius will end up as 14mm.
First question, should I design to this minimum radius they have given or will I get better results going over the minimum (I would prefer it as small as possible)
Second question, if I draw this profile out and add up the leg lengths I get different lengths for the inside and outside of the profile.
Do I just take the center line of the profile and use that as the dimensions for my flat sheet cutting?
Final question, when adding bend lines to the drawing I presume they just go in the centre of where the bend will be?
6mm sheet.
