graffian
Seer unto the end of his beard
- gatwick
I have always used one of the old fibreglass BOC masks, then[in 2003] I bought an optrel cartridge on ebay. It worked great and soon after I was given a slightly smaller shell, fits inside a wheel arch;-)
Today went to weld something together and the mask didn't get dark!
If I looked at a fluorescent the mask went dark, if it hadn't been used for a few days it wouldn't go dark immediately, it did when you stuck an arc though, it also darkens with the HF. Today it got dark when the light was at a very narrow angle, shining down on the cartridge[the cartridge is mounted upside down]. I put a new splatter shield in and it did seem to improve a bit, still not going off when you look directly at a fluorescent. It did work though.
Do they play up then die?
I see mention of batteries, not aware of it having any.
It's something like an Optrel Comfort, it has an adjuster which would be on the left lower side[would work it with your left hand] if the lens was the right way up.
Nearly forgot, are the inside polycarb clear bits meant to be replaced, looks like it's glued onto the cartridge.
