Sidewinder
- On A Whim And A Prayer
Hi peeps,
My first thread, I have found it interesting in here, and, it has taken me back 20+ years from when I started, and almost went down the coded welding route, but, instead, turned the corner into maintenance work.
I am looking into getting a TIG set and replacing our old oil cooled arc set at the same time, as it is the REALLY old type with the secondary return lead connected to the primary earth, thus, it can cause all sorts of issues, and yes, probably should not even be in use!
I have had made some enquiries and have had a couple back, two of which I would like some help in comparing as they are in the same "ball park" budget area.
I have been offered this, new, 5yr warranty, collected from local supplier:
http://www.jasic.co.uk/tig-315p-acdc-digital-welding-inverter-64-p.asp
Or one of these, used, 6m warranty (I think):
http://products.esab.com/Templates/T041.asp?id=144757
On an Esab trolley with water cooler & two Esab TIG torches, return lead & clamp, gas reg, Esab TIG gloves, helmet, arc electrode holder with cable, and a foot pedal, delivered to our premises.
Any help gratefully received.
Thanks in advance.
Thanks in advance.
