Can you give me your opinions on this bit of welding please???
I didnt have the confidence to go all the way to the edge of the hinge. I made the hinge from 10mm tube with a 1mm wall and 8mm rod, welded to 20mm box with 2mm wall
Peter - it's actually part of my 1st welding project (I have a thread about it in the Projects forum).
Marty - thanks for taking the time to reply on both threads, I know why the weld mssed the top, I welded that part left handed instead of turning the work around, nevermind I will not make that mistake again.
Bob - thanks, it's so hard when your starting out. I think the biggest thing is listening to the sound that the machine is making, also getting in a comfy position before your start your weld really helps me, I don't know about what others think about that.
Absolutely. Try and brace yourself somehow by leaning against something solid etc. Do a dummy run to see that you can move from start to finish easily. Also, if you are putting down a long run move into a more comfortable position as you lay the run down rather than moving into a more uncomfortable position, if you see what I mean.
