Hi folks I'm new on here and need some help. I have just bought a Cut 40 plasma cutter off the bay and the "instructions" leave a bit to be desired to say the least. Can anyone tell me the role of the switch on the front panel which has 2 settings 5.0s and 2.5s. I mainly want to use it to cut 0.8mm up to 3mm sheet (steel) - what settings should I use and at what pressure should I set the air regulator
I would also like to know do I actually touch the material with the torch continually, initially or never during cutting. Thanks
