Parm
Respect The Sound System
- Towcester
Im planning a new workshop build this summer and also want to upgrade the electric supply, this bit will be done by an electrician Mate
The new cable has to feed an outside store with a chest freezer plus a 2kw heater, then on to my barn which has 2 off 2kw heaters and then finally to my workshop with the usual range of stuff, none of which is run at the same time
Each of the three buildings has its own consumer unit
The total run will be about 30 meters
What size of armour cable will I need?
Is 10mm enough or should I go to 16mm?
