brightspark
- yarm stockton on tees
what are the randomly spaced small black squares on tape measures that dont relate to any particular measurment
centers for studs on walls ,,,, those ones ?what are the randomly spaced small black squares on tape measures that dont relate to any particular measurment![]()
On a similar note ,, I once had a really nice stanley tape that got damaged at the end ,,, but it was new and expensive at the time ,,,, so I just cut the last four inches off , and rivited the end hook back on ...
no bother ,,
I was making gates at the time for folk ,,, I never had any bother ,, my stuff fitted really well once made .
other folk working off my drawings and measurements just couldnt say the same ,,,
no bother ,,
I worked for a tight wad with a few tapes like that .We have a fibreglass roll up tape in a nice leather case & it has lost a couple of inches off the end. It has seen many uses over the years & it's no problem as long as you remember to add on the missing inches!
Yep , ,,, its a lot easier to cut a bit off , than it is to try and cut a bit on.I worked for a tight wad with a few tapes like that .
Funny watching the bellend throwing money away reworking stuff , even funnier if it's been away for galv and powder coat !
From the blurb in that link, basically spacing studs out.Thanks never knew what they were for. So my tape has 16" multiples marked in black, great for 8' x 4' sheets I get that but on @pedrobedro link it jumps to 19.5", don't get that at all just doesn't work on a 4' wide sheet.
Only OK if laying sheets horizontal though as far as I can see
The first black diamond is at 19.2” and after that black diamonds appear at 38.4”, 57.6”, 76.8” and 96”, or 8-feet. That is one less stud for every 8-feet of wall, counting the beginning and end studs.
no there not 11mm osb board or chipboard are the worstOnly OK if laying sheets horizontal though as far as I can see
