When I was much younger, I remember running and huge old water cooled tig in the corner of the maintenance shop. I was new to it but within a few minutes I was doing pretty well.
Here I am 20 years later with what I was told was a good all around tig. It's a Chineese (please don't flame me) unit called an ADC200.
It's got way too many knobs and I don't know where to start. The manual isn't much help.
Here are the specs on the machine:
and you can go here
http://plasmatigandmig.com/html/adc200_pulse.html
for a picture and specs.
ADC 200 MAIN CONTROL PANEL
ARC/TIG welding mode- Mode of MMA or TIG for AC and DC TIG welding
AC/DC Welding Mode Option - Mode of AC on or DC on.
2T/4T Mode -
In 2T Mode: When pressed down the arc ignites with upslope mode followed by desired current (main current). When When depressed the down slope mode is activated followed by the post flow timer.
In 4T Mode: When pressed down the arc ignites, when depressed upslope mode is activated followed by main welding current. When pressed again the down slope mode is activated then when depressed the post flow timer is active.
DC/Pulse - When the switch is at TIG mode, presses it at PULSE, and there is DC
Indicator of protection - If the machine works continuously for long time under large current, it's inner parts may get burnt as a result of overheat/ To avoid this, we set the pilot light, when it's on, please stop using the machine but don't turn it off, and it will recover after 2 or 3 mins.
Indicator of abnormal phenomenon - If the machine has abnormal phenomenon, the light will be on, when you should turn off the power supply and restart the machine to see if it's normal again, if it's not please email us or contact your local welding store.
Digital current display - Shows current reading in amps while welding.
Pre-flow time control - To guarantee the welding efficiency, gas flow before current, this switch is to adjust the time between gas and current.
Current time control - it's for current adjustment and changing the volume of current.
Base current - At DC TIG pulse, this button can adjust the volume of current.
Down slope control - As you are about to finish welding the down slope controls the time it takes for the current to reduce gradually from the crater time, until it stops.
Up slope control - As you are about to start welding the up slope controls the time it takes for the current to reach the desired welding current.
Arc force control - If you adjust this switch at MMA, then it can change the welding characteristics of low current.
Pulse Current - At AC TIG pulse, this button can adjust the volume of current.
Pulse frequency control - At DC TIG, and place the DC/Pulse at Pulse, this switch can adjust the pulse frequency from 0.5-25Hz.
AC frequency - The AC frequency allows you to alter the deposition rate allowing you to weld low gauge sheet metal. The AC frequency ranges from 20Hz to 100Hz
Pulse width control - In AC TIG welding the current exchanges between positive and negative terminals (when current is from the tungsten to work piece), it's positive direction for removing the oxidized coating on the surface of the work piece but the tungsten may be easily damaged because of overheat. Therefore if the current is negative ( work piece to tungsten) it will produce minimal heat. This switch if for adjusting the current time between positive and negative, When it's at the middle, the proportion is 50% at the maximum 80% at the minimum is 20%. If in clockwise direction, the positive current time turns longer and negative one shortens, and vice versa.
Post-flow time control - The work piece may be oxidized because of heat, so it needs to cool with the welding gas for some time as long as 10 seconds, this switch is for adjusting the post-flow time, pulse current out.
FEATURES
- Welds low gauge steel to 12mm
- Infinite welding current
- 60% duty cycle
- Light Weight Machine (25 KG)
- Welds Aluminium, Mild Steel and much more...
- Rubber Feet for anti vibration shock to PCB's
- Can Support 1.0-4.0 mm Rods
I'm trying to weld 16 ga cold rolled sheet and haven't had any luck at all
Gas is 25% Argon 25% Co set to flow around 23 (maybe too much?)
My tungsten is 3/32 and has red markings, I'm using DC.
Does anyone know where I should start with the settings? I've tried both the footpedal (gets way too hot) and the torch switch (not hot enough)
I'm lost.
Thanks much.
and you can go here
2T/4T Mode -
FEATURES
- 60% duty cycle
I'm lost.
Thanks much.
