- Birmingham
How old?, ballscrews have been around over 100 years.Older machines wouldn't have them I assume?
Forgive my ignorance but what is the advantage?
...getting the poohoo treatment...
That's one hell of a machine, is it running now?It depends on the machine. The Hitachi Seiki 4 axis ,live tooling Cnc lathe I bought cost me roughly £1k to get the parameters put back into it after spending about £3k on parts. No way an after market set up would come close at that sort of money.
Well this is only true when the acme is new. As soon as it wears you get backlash.You can have no backlash with an ACME thread. The penalty however is friction (or to put it another way efficiency).
Yes, it's all about the backlash but the reason why you pick a ballscrew over an acme is for the same backlash the ballscrew is something like 90% efficient while an acme is maybe 40% efficient.
Same goes for the rapids, the ballscrew means that you need smaller motors for the same speed (or more speed for the same size).
It really depends on if they know what they mean when they say parameters lost.How hard is it to set these things back up?
The biggest power loss is the slideways not the screws
Yes you can have low backlash with a acme thread with sprung split nuts but friction and wear is high
How long do you think a spring nut acme( manual is no good) will remain good
Wear also means less long term accuracy
So you go for ball screws for long term accuracy
My experience is based on a career of building machinery not googling answers!
Sometimes I think I’m a prizeidiot for even posting on this forum and getting the poohoo treatment
Time for a break I think
Very worrying that a simple software error can cause this!Also, depending on the size of the machine, beware of altering settings you don't understand
Kit maker Genie fined after M25 work platform death fall
Court hears how calibration error led to death of worker when 40 metre high mobile elevating work platform collapsedwww.constructionenquirer.com
Older machines probably had simple limit switches etc.
My forklift was out of action for 6 months due to a simple sensor fault. I even had the main service engineers out who couldn't fix it. I managed it in the end but I wasted about 60 hours of my time on it. Older forklifts just had valves!
Good thing a cnc machine can only eat itself then....
I would suggest that if someone has converted, rebuilt or fitted a new controller they would be capable of setting the callibrations...
Why? What is the connection here?I'd post some pics of arms wrapped around lathes or scalping injuries (hair pulled into machines and the scalp being removed) as a counter point to that, but I don't think it's necessary
And the risks are that the machine eats itself. Its as if you suggest it will chase the operator out the door?I'm not all doom and gloom, but the access to large machinery, especially CNC that needs modifying, does come with certain risks and I was highlighting what can happen when settings are changed that are not fully understood
Yes. All sorted. Just putting all the covers on and sorting out the cover on the tail stock. It all fires up though, can reference axes, do toolchange from the turret or from the carousel at the back. Spindle is nice and quiet. It’s been a long haul to get here !
I gave in a couple of months back and had a month away from here.The biggest power loss is the slideways not the screws
I think more people are killed by Normal sized machines.Why? What is the connection here?
Ok, if you're talking about one of the massive machines that @pressbrake1 has, yes, I could see it being potentially dangerous. Wouldn't put it past @fizzy to buy one....
Ai, but it doesn't need to be cnc to do it. Ultimately the machine if its cnc has a door switch...People get complacent. A small machine has the potential to make you just as dead as a big machine,the only difference being a big machine will get the job done quicker….Neither stop when you cry enough…
