5% is generally regarded as the best gas for thin sheet...BOC Argoshield Light or equivalent (actually 3% CO2, 2% Oxygen & 95% pure Argon).
Never used gasless but CO2s 'orrible. 14% CO2 is quite a bit for 1.5mm. If that's the sort of thickness you weld most often I would suggest something with a bit more argon. I may be wrong though...!
weldequip said:5% is generally regarded as the best gas for thin sheet...BOC Argoshield Light or equivalent (actually 3% CO2, 2% Oxygen & 95% pure Argon).
malcom said:North Americans seem to go for higher CO2 mixes, so I guess the ratio in the disposable mix has come from over there.
Ar/Co2 is 75/25 here called Argoshield C25 here (they had to put the argoshield name in there). It is the standard for short-arc welding. Tri-mix is not popular here. Lots of flack about negative effects of O2 (fast cool of deep weld pool trapping O2.)
