If it were in Welderpaul's workshop & HSE called round they would condemn the lot!
Oxygen regulators should now be rated at 300bar, the Acetylene regulator is, as Paul said, older than him
The Torch is long obsolete (although you can still get nozzles) & the Flashback Arrestors are most likely well out of date. The hoses look pretty new...you can test these by bending them into a 'U' shape, if they crack on the U bend they are fecked...otherwise should be OK.
It could all still be in working order & there is a hell of a lot of similar gear still in use, but you do so at your own risk
weldequip
The Torch is long obsolete (although you can still get nozzles) & the Flashback Arrestors are most likely well out of date. The hoses look pretty new...you can test these by bending them into a 'U' shape, if they crack on the U bend they are fecked...otherwise should be OK. It could all still be in working order & there is a hell of a lot of similar gear still in use, but you do so at your own risk
weldequip
