richie00boy
I have a 2013 Zafira, 1.8 petrol. It's running OK, but there is an engine light on so I checked the code with an OBD reader and Torque app and it reported that the heater on the pre-cat O2 sensor is not working. I have measured the heater resistance at 10.4 ohms which I believe is fine, so I went on the look at the voltages on the heater wires (with the plug disconnected). Across the wires I got nothing. Measuring with respect to earth I got battery voltage on one wire and the other had about 3V on it for about 20 seconds after starting the car then it dropped away to nothing.
I also have an Astra 1.6 petrol so I compared the measurements, on that I get 3.8V at startup and it remained at 3.8V for the minute I was testing.
So I think this must mean that the loom is OK but there is something wrong with the ECU? Or possibly a relay in the circuit with bad contacts?
Also, the battery voltage on the Zafira is higher than I expected - 14.2V. Could this be indicative of an issue or maybe even have damaged something?
