I'm having some issues welding in some tubes on my dragster chassis. The main structure of the chassis is tig'd by a pro but I'm adding brackets and some extra tubes with my MIG. I have a Sealey / Siegen 150. It's OK, far better then the little SIP piece of crap I had before. I get good results welding pieces up on the bench but just can't seem to get a decent welds on tube "in position". The torch and liner is new, earth clamp fine.
It's 3.2mm CDS tube, welder is on 4 of 4 heat setting and nearly full whack on the wire feed. The set never really has the bacon frying sound, but I have got a good stable arc, just doesn't crackle ! Wire diameter is 0.6mm and gas is Argon/CO2 mix. When welding in position on tube, I'm struggling to maintain torch angle and I'm getting spatter as a result. I'm seeing the end of the wire ball up whilst running a bead as well. I dropped down to 0.6mm wire ages ago simple because I found it easier to produce neater welds as I'm a bit slow running the bead and because my previous set struggled with it.
Should I be using 0.8mm wire ? and what technique can I use to help maintain a torch angle when welding tubes around 32mm ? I've turned and flipped the chassis to get the best position, but I seem to be fluctuating between pushing and pulling beads based on access and result are inconsistant.
Anybody got any pointers ?
