Hi,
I'm using 1mm wall mild steel 16mm box section. I have 2 lengths touching lengthwise parallel to each other and I'm welding along the lengthwise join. My question is what sort of penetration should I be looking for? i.e if I look inside the box section should I see some penetration? At the moment I can run a bead fine along the join but see no penetration. If I put the amps up I get some penetration to the interior of the box section but also tend to burn through. As such I'm a confused newbie.
Many thanks in advance
Noel
Noel
