cardiffrob
- Wales, Llantwit Major.
We have a curious problem in our new house. You can run hot and cold water through some of the mixer taps but the cold seems to overpower the hot feed and then back-flush the hot water line with cold water. Is there a solution to this? The shower works alright with a pump to it but all other taps, to one degree or another, will do this back-flushing thing. If you run a bath with both taps open it merely fills the bath with ice cold water!
I've tried to work out the design of the copper 'spaghetti' at the back of the tank but am stumped. How can you balance the pressures without having a pump running full time to keep the hot pressure up?
Any suggestions would be gratefully received. The walls are about to go back up on the extension so now is the best time to sort this out and I don't know any other sensible websites inhabited by grown-ups.
Not that it helps I know,
-------------- I am always in HOT water!!
generally from the missus.
