I have used these cylinders for some years and have never experienced a gas leak. So when I came to use an almost new one only a few months old I was surprised to find it empty. Contacted Machinemart and of course got I guess the standard answer did you disconnect the regulator. The answer is no , I have never done this with any cylinder as unless I am 'thick' as long as you unscrew the regulator valve fully whether you unscrew the valve or leave it in place you are relying on the sealing of the cylinder valve. Am I right. So do I have a complaint with Machinemart re a faulty cylinder seal. They say they will test the cylinder but I am dubious of their honesty to check out. I do not want to buy another, use a couple of times and then come back in a few months to find empty. Am I doing something wrong, or could there have been a batch valve fault. Machinemart argued that if they leaked then they would be empty in a short time on their shelves, so why did the guy shake the one I bought, I was told that it is not unknown for someone to try and swap an empty one for a full one, never had this before with previous ones purchased.
