robertbruce
hi everyone...
I have some patch-panel to do on my vehicle so off to supercheap for the 140A G/NG MIG welder...
got it home and started mangling some steel...
Some questions i would like to ask.....
In the images below I am concentrating on penetration, yes i need a new tip...
I am using flux core...
My mask is hopeless, no straps but some rope, moves around, presses against my nose and scratchs' my glasses. It usualy moves when i start the weld, gota get a decent mask...
Have i selected some suitable practice steel?
The first one is 1mm steel plate that i have had lying around for years. I originally picked it up from a campsite on fraser island. I would not know the difference between plate steel or panel steel but this piece seem very stiff and hard...as you can see i have grinded it off as cleaning
The second piece is a PC case, again the coating ground off for cleaning...
I think i have penetrated enough but i;m not sure about the bead? Should it be higher than the pics...
workarea
1mm plate steel
1mm plate steel
PC panel steel
PC panel steel
a huge thanks for any help
workarea
1mm plate steel
1mm plate steel
PC panel steel
PC panel steel
