Hi all,
I have a clarke 160, which i brought from ebay.
The weekend a friend came round to show me how to use it so i was not fighting in the dark, but we had wire feed problems, so yesterday i had a service kit, and then tried to fit it last night.
All went well, or so i thought until the wire stopped coming through. The wire was not been pushed up the torch lead. The problem was inside by the wire feeder, it had kinked.
So i sorted that out, and tried again.
To cut a long story short, I think the welder i brought was missing bits, and the bits i had in the service kit, i guessed to where they should go, and some bits i had not got a clue. The part in question was a small wire thing, that was slightly larger the one end, and i assumed this went into the swan neck.
But due to more wire problems, i moved where i put this and now it is broken.....
I took the swan neck off and how i left my welder late last night was with the wire just popping out from the brass square thing in the handle, and not going any further.
The wheel that feeds the wire, stamped on mine (which i can see) is 0.8 does this mean that i am using the 0.6mm side or not?? That may be a problem i thought about when i was trying to sleep.
Any help, comments, insults, would be welcome. I just want to learn to weld
Thanks
Thanks
That's how I figure it out as the markings are confusing. Normally it will be the one closest to the edge marked 0.6.
