triumph5ta
New Member
Hi, I will soon be the proud owner of a Clarke 130en Mig welder. I do mostly motorcycle restoration so my use of the equipment would be occasional and pretty light. Although I am sure as I get better at it I will use it more, fabricating odds and sods.
Now for the fuel tank bit.
The fuel tank in question is from an old Triumph 750 and has not held fuel for at least 30 years. During that time it has no petrol cap on it and has been flushed out with water many times as part of the process to get loose rust out of it. What im trying to say is there is not a trace of fuel vapour in it.
The problem is that it has a few pin holes in the bottom.
I was thinking of simply building a blob of weld over each pinhole to fill it then grinding it flat... does that sound ok? Its really sound apart from the pinholes.
