On our camper restoration we are using Lechsys Epoxy Primer 29107 with standard 29370 hardener.
When picking up a another 6lts + 3 of hardener was asked slow or fast?
I am spraying outside in a poly tunnel and at try to only spray at 20deg+ (sometimes warm the panel with infrared's if it is below 20)
the data sheet advises not to dry at below 15.
Looking at the hardener cans the std has a 25-35 temperature range while the fast has 5-25. I don't think I have had any issue so far using the STD hardener.
but what would the issues be and should I be using fast?
Thanks
Thanks
