Hi everyone,
I spent some weeks perusing this website, the guides, and this forum before buying an SWP 150 Turbo mig machine and have now put some time in practising and practising, which has led to some questions!
Using 1.2mm mild steel plate for practising the whole time.
Started laying beads using 0.8mm wire and CO2. I discovered how tricky it is getting voltage and wire speed set right enough to get what looks like a half-decent weld. Found that I was either getting only spots of approaching penetration on the underside, or was melting holes through. If I didn't move the torch fast enough, holes. I was surprised to find that of the 4 voltage settings I have, I had to use the 3rd highest. Minimum just created slugs that sat on the metal. Second highest just slightly better but not blended into parent metal, 3rd seemed good. Even so, had to put up wire speed to get good penetration but then found it hard not to burn through sometimes.
Then I tried with some 0.6mm wire. Again I have to use the 3rd highest voltage setting, and found I could only get good penetration without slowing down torch speed to the point of burning through by holding the torch so close to the metal that the shroud is touching the metal. Trying to use the recommended distance of 6mm to 10mm causes poor penetration.
Latest I've tried is 0.8mm flux core gasless wire. This has confused me, as I've had to go to minimum voltage setting and turn the wire speed right down in order to stop blowing holes. Even with the minimum voltage and really low wire speed, it's still putting so much heat into the metal that if anything it's penetrating too far and the surrounding metal glows red after I stop, whereas with solid core and CO2, mainly only the bead was red hot.
The beads are terribly ugly with flux core, but if only I could achieve that penetration so easily with solid core. Please advise! I'm a bit confused with my differing results.
Thanks.
Thanks.
