vmaximus
- Kirkby in Ashfield, Nottinghamshire, U.K.
Hi chaps, just received a new welder today, a Thermal Arc SE175 inverter welder. I am a occasional Diyer and my first impressions are very positive with this m/c but what I want to know is, do inverter welders need less amps to weld than my old 30 odd year old Cebora buzz box. The reason I am asking is because I have tried it out on 2mm s/steel plate using Oerlicon 2.5mm 316 rods but had to turn the amps down from 80 to 50ish amps to get decent welds without it blowing through, also I used 3.2mm Oerlikon 6013 rods on 3mm mild steel and had to turn down to about 80 amps for the same reason. On my Cebora I used to use around 80 amps for the 2.5mm rods and 100 amps for 3.2mm, is the above settings about right for this type of welder. I know that I will have to play about with it some more and get used to it but am I on the right track. Thanks in advance for any info. Pud.
