EddieMunster
New Member
- UK
I'm set on getting from Draper, but that's as far as i know when it comes to welders.
My budget for a welder would be around £200 although the option 3 I'd be willing to go that much, i still need to buy the safety gear, and i honestly don't want to skip on that part.
I'm not to keen on the idea of using gas as i have noi real safe space to store it, and i heard it can be expensive if I'm not going to be welding a lot, like for a job or hobby.
So, i want something i can simply plug into the home wall socket (UK) and just get going, but perhaps the option to use gas if ever i might need/want it.
I added option 1 just in case that'd all I'd really need, but knowing me, and like many of you I'm sure, when you have the tools for the job, you suddenly find the inspiration to create things that otherwise you'd never have thought of, so this is where the option 2 and 3 comes into the mix. Plus i don't want to get a welder then realize, "i should have got the more powerful version".
So, I have a chainsaw, and i use it a fair bit, like 3 times a week, and so one of the things i was looking to make was a steel chest rig that'd be sewn into my "safety overalls" just so i feel totally safe, and then make some upper and lower leg plates to complete the suit.
I also have an old pair of work boots (well, kinda like wellies) that i was thinking of making a steel outer layer, (think of those old steel divers boots). I know steel toe caps are best for chainsaw users since the chain simply skips off them, unlike the so-called 'chainsaw boots' with the plastic toe in the boot which actually doesn't stop a chainsaw from doing serious damage before the blade is stopped by the fibers.
So if i ever wanted to do such jobs with thick steel, or thick enough steel, which one of these welders would be good enough?
GASLESS
1/ http://www.drapertools.com/product/32728/Gasless-Turbo-MIG-Welder
Phase Single
Input current 13A
Output amperage range 60 - 90A
Amperage at 35% duty cycle 60A
No load voltage 26-30V
Wire size-flux cored 0.8mm
GAS/GASLESS
2/ http://www.drapertools.com/product/12033/140A-230V-Gas-Gasless-Turbo-MIG-Welder
Input current 16A
Output amperage range 40 - 140A
Amperage at 35% duty 75A
No load voltage 23-38V
Filler wire sizes 0.6 - 1.2mm
GAS/GASLESS
3/ http://www.drapertools.com/product/12019/180A-230V-Gas-Gasless-MIG-Welder
Input current 16A
Output amperage range 40 - 180A
Amperage at 35% duty 100A
PS, would i also need a respirator for any fumes from the metals? If so, which one would be best for use with a full welders mask? I honestly don't want to wind up with some horrible respitory disease or something like that when I'm older.
GASLESS
Phase Single
Input current 13A
GAS/GASLESS
Input current 16A
GAS/GASLESS
Input current 16A
