DStanley1809
New Member
- UK - Midlands
Hi All,
Me and a buddy have decided to build a kit car and an important part of this project is learning how to weld!
We've started practising using 1mm sheet steel but haven't had a great deal of success there. Lots of sputtering, black residue and what looks like marbles on the surface. Somehow we managed to not blow through this steel at all.
At first we just tried running beads then tried welding to edges together, using settings from various different online "calculators":
From the ease with which we could separate the edges we know it was a bad weld, just sitting on the surface.
This was a a couple of weeks ago and we tried again today, using some angle steel and taking our own guesses at the settings. I think it went much better as we were getting a consistent crackling sound instead of popping and there is much less black residue. We seem to have had some success in attaching two edges together.
It's not pretty and looking underneath it doesn't seem to have penetrated all the way through but when you beat on it with a lump hammer the metal bends before the weld gives way. We couldn't get the weld to bend or crack at all.
After this we cut up some more angle and put it together to form box section and welded that up. Again, we were unable to break it and the metal walls started deforming before the weld did but inside the tube we couldn't see any penetration.
Is this a "good" weld or do we need more penetration?
