Hi there,
Been lurking for a while - absorbing all the great info on the forum!
I bought a Clarke 150TE a while back with the intention of making all sorts of cool stuff, yet havent really got around to practicing with it much (intend to change that)
Anyway I now need to do a spot of welding on my car and want to get opinions from those in the know of the best way to go about it.
1st problem is 1 of the seat mounts has pulled out of the floor - possibly due to rust around the securing bolt. Obviously I want to sort this. The floor pan is 1.2mm thick.
Now should I get some steel plate of similar thickness, cut it to size, tap a hole, weld a bolt to the back side and then weld it over the top of the existing location? Would that be adequate - can anyone see any issues with this?
Here is the problem
Is there a better, stronger, safer option?
Will obviously practice to make sure I can get good penetration on the 1.2mm steel before attacking the floor.
Any help and advice is greatly appreciated.
Regards
James
Here is the problem
Regards
James
