Welding Bear
- Northampton
Hi there, hope you're all well.
I have had a brief welding lesson and I believe the time has come to get a welder and do some practising.
I have details of the first welder I'm going to get, welding mask, gloves, tin snips etc. so that's all sorted.
I will simply be buying some steel and practising. I feel that's the way to go.
The goal is to repair an area on my car that spans around 5" in width from the sill to just before inside of the rear door:
As you can see from the photo I'll need to remove some plastic trim and the sill cover. And then the plan was to cut out that rot in the pic and where it stretches to the sill.
I'm a little confused as to what to do with the shaping of this part. Presumably I can just bend a piece of metal like in this profile drawing:
.....trying to match pretty much what I cut out?
Also, as this is only a small area of rot and on the sills am I going to have to worry about the door not finishing level? Or is that just if you were to remove the whole sill?
TIA for your thoughts
