Hi all. Been a few years since Iv'e posted.
Basically , Ive now got 2 welders. A cebora 130 turbo, had it a few years and been almost a constant pain in the rear end since ive had it. Recently bought a clarke 196 (180 A) to replace as want to start from scratch with a new non abused machine.
Firstly the Cebora , its recently started wire feeding itself when off the trigger. A bit scary when not expecting it. Ive opened up the gun and cleaned everything, looks ok from a non pro perspective. cleaned contacts on plug, just to make sure. Im not sure of the technical names,so please bare with me.
The gun cable gets pretty warm to the touch with barely any use. Any ideas ?
Now the clarke. It came supplied without a plug. I know it can be used on a standard 13 amp plug but no on full whack power for long. Thing is , the cable ends are a good bit thicker and have , i think, little connectors on the end which wont fit in a standard plug. Can anyone advise on what plug I can put on it?
I only have standard 13 amp socket power . Ive looked on ebay for heavy duty 13 A plugs but none show the insides so I dont know if the wires will fit in. Can I just cut off the , spade?,ring? connector things and put the wires in as you would a normal plug ?
I hope that makes sense . Im not well versed in the tech sides of these things as im sure you can tell.
Thanks for any help, feedback .
Cheers
Cheers
It will happily weld on the highest settings without blowing the fuse but I am protected by the mcb & trip on the board. I have a 16a socket but I haven't got around to fitting it, can't decide on the best location!
