Wow... There seems to be a forum for everything these days, I'm glad I found this site.
I have a new welder and am having problems getting it working correctly with 6mm wire. When I try to start the weld the wire seems to always burn back to the tip and then stick for a couple of seconds - it does this with any speed setting / current setting. The wire is very slightly corroded but worked ok in my old Clarke MIG90.
I have tried with 08mm wire and tips and this seems to work fine - although I've now run out of gas so can not fully check until tomorrow.
Has anyone got any ideas? the wire seems quite tight on the tip - should i widen the tip slightly?
Thanks in advance guys..
